How can we assign feeds and speeds our tool geometries ?
Hi
We want to take automatically feeds and speeds dimensions when we choose tool geometry . Because sometimes i am using same tool with one or two operations.
But feeds and speeds are same diemensions and we cant assign dimensions tool geometries.
Any idea about this ?
Re: How can we assign feeds and speeds our tool geometries ?
I'm not sure I understand the question - in particular what you mean by tool geometries and dimensions. Can you show an example of what you are trying to do?
You can assign specific speed and feeds to a library tool in Edit Machining Data Libraries  > Tool Machining Data - is this what you are looking for?
You can also have the system calculate speed, feed, cut depth, and stepover based on the tool material, tool diameter, tool length, part material, and cut method.
Mark Rief
Retired Siemens
Innovator
Innovator
I would start with 42.
Proud Member Of The Reality-Based Community.
