04-15-2014 08:32 AM
Where can you set the time a turning tool will run before either calling a redundant tool or going to your tool change point ?
Solved! Go to Solution.
04-16-2014 01:57 PM
In the Turning operation, take a look at Non Cutting Moves, Local Return.There are options for distance, time, and number of passes. At the local return you specify the events you want, such aas an opstop to check tool wear. Is this what you are looking for?
