How to Let FBM detect the machining direction for a step1 through hole without chamfer
I added two rules in the Mapping rule, but it didn't works.
is_defined(mwf.MACHINING_DIRECTION)
REM IF mwf.MACHINING_DIRECTION = "BACK" THEN
REM ((mwf.X_ORIENTATION_D = -lwf.X_ORIENTATION_D) AND (mwf.Y_ORIENTATION_D = -lwf.Y_ORIENTATION_D) AND (mwf.Z_ORIENTATION_D = -lwf.Z_ORIENTATION_D))
REM IF mwf.MACHINING_DIRECTION = "FRONT" THEN
REM ((mwf.X_ORIENTATION_D = lwf.X_ORIENTATION_D) AND (mwf.Y_ORIENTATION_D = lwf.Y_ORIENTATION_D) AND (mwf.Z_ORIENTATION_D = lwf.Z_ORIENTATION_D))
((mwf.X_ORIENTATION_D = 0) AND (mwf.Y_ORIENTATION_D = 0) AND (mwf.Z_ORIENTATION_D = 1))
((mwf.X_ORIENTATION_D = 0) AND (mwf.Y_ORIENTATION_D = 0) AND (mwf.Z_ORIENTATION_D = -1))
