How to add class in export tool to library ?
I want to add my tool to class ( I want to create new class is my company) .
Thank you.
Re: How to add class in export tool to library ?
I think, you can use a guide from NX help, there is step by step guide for adding new tool clases.
I try to attach picture to let you show where it is.
Vavrusa Ondrej
NX10.0.3
NX11.0.x testing
Like @Ondra says, the process to add a class is well documented.
But your subject line mentions exporting a tool, so maybe that is what you are looking for? Once you have modified the tool library files to include your new class, if you want to populate the class during export, you need to modify the ASC_ask_missing_aliases proc in dbc_tool_ascii_export.tcl.  By specifying the aliases for the proper tool classes, when you export a tool, we will bring up a dialog asking for the values to be used for any missing alias.
Mark Rief
Retired Siemens
Builder
Builder
I follow guide on New class and working ok. After define new class for ball mill with same method, export for ball toll doesnt work. How to define new class for ball tools?
HI should work the same way. I have no problem , I added new ball mill class and if I click on export tool to library it appears all my classes for ball mills and I only choose where I want to have my new tool
Vavrusa Ondrej
NX10.0.3
NX11.0.x testing
Builder
Builder
After export new ball mill tool to library, i dont see table "Select target class" - and TCL error.
Strange ... check if you change file dbc_tool_ascii_export.tcl in folder ...\CAMresource(or resource)\library\tool\ascii
and dbc_tool_general.tcl in folder ...\CAMresource(or resource)\ug_library here must be :
and it works
Vavrusa Ondrej
NX10.0.3
NX11.0.x testing
Builder
Builder
Ok, thank you. I found missing information under ball mill:
Now i see dialog for class select, but i have always TCL error.
There is not only one row where is new class declared. You must check it, if it is in all files according of some existing group (f.e. BALL_MILL_NON_INDEXABLE) or according to help guide.
Vavrusa Ondrej
NX10.0.3
NX11.0.x testing
Builder
Builder
Ok, I found another problem in my definition and now export is work.
Another question. After select my new Type:
i see all tools from "Milling" group too. Is possible separate?
