How to add the part materials in library as per our requirement?
To add your own Part Materials to the machining database,...
To add your own Part Materials to the machining database, go to Menu --> Tools --> Edit Machining Data Libraries.
To select the part material you are machining, editithe Workpiece geometry group, or go to Menu --> Tools --> Part Material.
Mark Rief
Retired Siemens
