How to configure NX 8.5 to run a post configurator post?
What is needed to use a postprocessor created with post configurator in NX 8.5?
The documentation only tells us about the machine kinematics, nothing else.
According to Post Configurator. What does this mean for the future of PostBuilder?, PC should be backwards compatible with NX 7.5 and above.
Re: How to configure NX 8.5 to run a post configurator post?
I get the following error in NX 8.5.3, but the same post runs well in NX 10.0.1 Smiley Sad
************* MOM: TCL SCRIPT MESSAGE *************
User message: ERROR: ***** Could not find file: Z:\NX Tests\Post Configurator\test_hhlib_execute_NX85_64bit.dll
************* MOM: TCL SCRIPT ABORT *************
User abort message:
*** EXCEPTION: Error code  1770001 in line 1159 of D:\workdir\Patches\NX853_patch\src\camsmom\no\ind\mom_tcl_definitions.c at Wed Jun 03 07:47:18 2015 Mitteleuropäische Sommerzeit
+++ TCL error returned when evaluating file Z:\NX Tests\Post Configurator\test_hh\test_hh.tcl
 Trace:
    while executing
"error "" "" "USER_ABORT""
    invoked from within
"MOM_abort "\n\n ERROR: ***** Could not find file: ${lib_ge_env(post_pool_dir)}$filename$lib_ge_execute_extension.dll""
    (procedure "LIB_Shell_load_user_function" line 24)
    invoked from within
"LIB_Shell_load_user_function "lib_execute_$lib_ge_dll_version" "JEDLL_NG_Execute""
    (procedure "LIB_Shell_init" line 19)
    invoked from within
"LIB_Shell_init"
    (procedure "LIB_Shell_main" line 46)
    invoked from within
"LIB_Shell_main"
    (file "Z:\NX Tests\Post Configurator\test_hh\test_hh.tcl" line 260)
This seems to be a known problem and I have now a PR#7407057 open for this issue.
