How to control order of pockets to be cut
I have a part with a lot of pockets and i want to control the order that they are roughed out. Under the connections tab there is an option to follow start points. My question is, how do i add start points for the operation to follow?
Re: How to control order of pockets to be cut
hi
Ihave never use it but I set follow start points and set start points like this:
