How to define a programming author in the CAM
Hello folks
In the following video at 9:47, he used post builder to check the programmer. But in my sample, I don't know how to define the programmer in the CAM.
https://community.plm.automation.siemens.com/t5/Tech-Tips-Knowledge-Base-NX-Manufacturing/Tool-Comma...
4 REPLIES 4
Re: How to define a programming author in the CAM
follow the video :
proc _USERNAME_ {loginID} {
switch $loginID {
"m.kn" {set username "mkn"}
"Sean.HAI" {set username "Seanhai"}
default {set username "Unknown"}
return $username
set camprogrammer [_USERNAME_ $env(USERNAME)] ; # rename '_USERNAME_' for not confused with variable env windows
Production: NX11.0.2.7,VERICUT 8.1.2
Development: Tcl/Tk, Gnuplot
www.adgroupe.com
So the mom_logname is my windows username?
ok Smiley Wink
set camprogrammer [_USERNAME_ $mom_logname]
www.adgroupe.com
Yes, this is the same as using the environment variable USERNAME on Windows.
MOM_log_message "$mom_logname \n $env(USERNAME) \n [MOM_ask_env_var USERNAME]"
The above should display the same user name in the NX syslog file for each command in a Windows environment.
