How to define te tool attached to perform an undercut.
Hello.
I need to define a tool to machine an undercut with streamline or cavity mill with undercut activated.
I have not been able to do it. I need at least the cutter area of the tool.
The tool is the following.
I have tried with a chamfer tool and I have got:
The problem with this chamfer tool I have is a very slow calculation and sometimes there are gouges into piece.
Frank.
