How to delete address from post
Hello Everyone,
i want to know how i can delete in my Post Prozessor some strings(commands) with G0 Addresses.
For Example, i want to get something like this:
if { ($mom_motion_type == "RAPID")} {
"Delete (only) next G0 Command in my Post"
It 's possible?
Re: How to delete address from post
What is the real problem?
What is the output you get and what should the output look like?
Can you offer the sample part and the post-processor?
Hello Stefan,
the real problem is that in my Post i have a dublicated commands.
In my Post i use for some operation a calling of CAM-macroses. There macro command must be called before NX-Command.
For Example:
Sample Macro  ("My_Macro"):
N9000 G1 X100 Y200
In my post:
N100 My_Macro
N105 G0 X100 Y200  (RAPID MOVE;  this command is dublicate)
N110 G1 X150 Y300
I want to have
N100 My_Macro
N105 G1 X150 Y300
hi,
try to use this in some logic:
MOM_suppress once G_motion
or
MOM_suppress always G_motion / MOM_suppress off G_motion
or
MOM_disable_address G_motion / ..enable
Another option...
MOM_do_template linear_move CREATE
If you use the CREATE key word, the post thinks the line is already output.
But (as the post thinks it is already output) you have to be careful about modality (e.g. maybe the NEXT line, the one you really want output, now needs a G0, but the post already thinks it was output.)
thanks a lot for your ideas but the next line will be outputed.
What is the source code of your macro?
Have you updated the positional variables, so that MOM knows that the position is already reached?
@ustus wrote:
As a precaution, you'd need to evaluate if My_Macro is declared/exiting before deleting anything from your output.
Something like below will wipe out that rapid motion right after My_Macro, and only if My_Macro_VAR is set to 1
### place into PB_CMD_before_motion ###
global mom_motion_event if {[info exists <My_Macro>]} { set <My_Macro_VAR> 1} if { ([string match $mom_motion_event "rapid_move"] || [<My_Macro_VAR>==1]) } { MOM_suppress Once G_motion MOM_suppress Once X MOM_suppress Once Y MOM_suppress Once Z
unset <My_Macro_VAR>
Hope this helps
Charles
Hello Stefan,
my macros are for plc-cnc control (vacuum hood up, down, to position 1 etc.)
I must give in my macros values of a next position and this position will be reached in macro.
So, i have something like this:
N1 a=100 b=200
N2 G1 Xa Yb
N3 G0 X100  (NX)
It's not bad that I have line N3 in my outpost, but it's dublicate.
MOM don't know that a position is altready reached. How I can do it?
Hello Charles,
my output after your recommendation is:
N105 G0
It's fast goodMan Happy
How I can delete this G0?
