How to edit END_OF_PROGRAM proceedure removing the T0 and M6 before the M30
How can be changed proc END_OF_PROGRAM in Post Configurator? I need only M30.
3 REPLIES 3
Re: How to edit END_OF_PROGRAM proceedure removing the T0 and M6 before the M30
Martin,
Try this:
LIB_GE_command_buffer_edit_remove MOM_end_of_program_LIB END_OF_PROGRAM OOTB_T0 OOTB_M6
Kind regards,
Majid
Majid
I think you just have to edit the settings of the tool change section to not output a tool change at the end of the program.
No need for buffer voodoo ;-)
Hi Majid,
thank you, it works perfectly!
Martin
