How to enable TCP in Post Builder?
Hi, Battleminder engineer! Help me!!!
I'm japanese student. I am researching 5 axis machining center.
Please tell me the specific method.I if possible,want a picture of the parameter to change.
Re: How to enable TCP in Post Builder?
Which postprocessor or even control? Various postprocessor templates decide how to turn on tcp in different ways. Some decide based on operation type. Others by a ude setting. Still others by a variable setting - usually in start of program custom command. Generally - for tcp for all included rotaries - the motion axis addresses will use "mom_mcs_goto" variable instead of "mom_pos".
NX12.02
Windows 10 Pro
Reply, thanks.
I changed the setting by the way shown in the figure.(Figure1,Figure2)
After opening the post processor I wanted to modify in the post builder, I modified it in the following way.
1. click "Program & Tool Path". (Figure1)
2. click "Proguram".
3. click "Proguram Start Sequence".
4. click each sequence.
5. Change "mom_pos" to "mom_mcs_goto". (Figure2)
But TCP did not become effective.Was my method wrong?
Please reply to beginners of 5 axis machining center.
NX11
Windows 10 Pro
Machine   dmu75mono-block
Control device   FANUC Series 31i-MODEL B
Figure1-1.JPGFigure1
Figure1-2 .JPGFigure2
