How to fix the decima place display?
I am using NX10, when I creat a skecth and use rapid dimension, I can show 3 digit after decima place (ex: 2,004 10,001 ...) But I only want to show 2,1 when the dimension is 2,100. 5,3 when the dimension is 5,300. How to do that?
Re: How to fix the decima place display?
Hi @Vanphu_ht91,
Please folow the steps below.
1 - File > Utilities > Customer Defaults.
2 - Click on Drafting > General/Setup > Customize Standard.
3 - Click on Dimension > Text.
3.1 - In Decimal Places select the number of decimal places you need.
3.2 - Turn off Show Trailing Zeros.
4 - Click Save or Save As.
4.1 - If you click Save As you will need define the name for a New Standard.
5 - In Drafting Standard, select the Standard you have modified or a New Standard you have saved.
6 - Click OK.
7 - Close NX and Open again.
I hope it helps.
Jean Marcel
PLMPRO
www.plmpro.com.br
