How to get Tool Description in place of Tool name in CLSF file
Hi
I use CLSF_ADVANCED to generate CLSF file
Is it possible GETto TOOL DESCRIPTION instead of TOOL NAME
eg:
TOOL PATH/TOP_FACING_RUF,TOOL,TS0205M001
now TOOL NAME is generated
instead I want to get TOOL DESCRIPTION in this place
Re: How to get Tool Description in place of Tool name in CLSF file
look at ...\MACH\resource\tool_path\clsf.def and search "BLOCK_TEMPLATE tool_path"
BLOCK_TEMPLATE tool_path {"TOOL PATH/"\nows
                          GM1[$mom_path_name]
                          Tool[$mom_tool_name]}
in clsf.tcl you will find for each TOOL PATH/...
MOM_do_template tool_path
 an advice : make a copy "BLOCK_TEMPLATE" or "clsf.def" and modify
Sorry I don't remember the mom_variable for tool description
@mkn
Production: NX11.0.2.7,VERICUT 7.3.3
Development: Tcl/Tk, Gnuplot
www.deshors-tiremold.com
it worked
replaced tool_name with tool_description in clsf.def
Keep in mind that the TOOL PATH statement is part of the CLSF syntax. Applications that read the CLSF may not handle the description text.
Mark Rief
Retired Siemens
Gears Legend Gears Legend
Gears Legend
Another option is to create a custom procedure and source the regular CLS output.
In this sample below, the following is written after a tool change:
The tool description in the form INFO/'This is a cutting tool'
If a tool has the option -Coolant thru- active, a statement is written in the form INFO/COOLNT,THRU
 Output:
 LOAD/TOOL,12345,ADJUST,1
 INFO/'END MILL D20.0 R2.0 3XD'
 INFO/COOLNT,THRU
In the post (icam's campost) actions can be taken on these INFO statements.
source [MOM_ask_env_var UGII_CAM_TOOL_PATH_DIR]clsf_advanced.tcl
#____________________________________________________________
# Load Tool
proc MOM_loadtool {} {
   global mom_load_tool_number
   global mom_tool_adjust_register
   global mom_tool_description
   global mom_tool_coolant_through
   if {[info exists mom_load_tool_number] == 1} {
      if {$mom_load_tool_number == 0} {
        MOM_output_literal  "ERROR: No Toolnumber defined"
      } else {
	    MOM_output_literal  "LOAD/TOOL,$mom_load_tool_number,ADJUST,$mom_tool_adjust_register"
		if { [info exists mom_tool_description] } {MOM_output_literal  "INFO/TOOL,'$mom_tool_description'"}
		if { [info exists mom_tool_coolant_through] == 1 } {
		   if {$mom_tool_coolant_through == Yes} {MOM_output_literal  "INFO/COOLNT,THRU"}
   catch {unset mom_load_tool_number}
   catch {unset mom_tool_adjust_register}
   catch {unset mom_tool_description}
   catch {unset mom_tool_coolant_through}
By sourcing the regular output, this will not be affected by NX updates.
Patrick Delisse
KMWE - DutchAero
NX 12.0, TC 11.2, CAMPOST V22, Vericut 8.1, TDM 4.8
C#, VB, .NET
