How to hide tabs in the "file/new" environment
Hello everyone,
I need to hide some of the tabs that appear when starting a new file.
There appear several options to start a new project and i would like to know how to hide those tabs to make it easier for new users.
Attached there is an image where you see the standard configuration
I´d like to hide tabs like (mechatronics concept designer, ship general arrangement, press line, ship structures,....... )
4 REPLIES 4
Re: How to hide tabs in the "file/new" environment
NX version = 11 or 12 or ?
Current Nx version Nx12.0.2.9 MP03
Thanks in advance
Hello @hberrueta,
I believe you will find a usefull information in the link below.
https://docs.plm.automation.siemens.com/tdoc/nx/12/nx_help#uid:xid1128416:index_working_with_files:f...
I hope this helps.
Thanks.
Jean Marcel
Application Engineer
Ally PLM Solutions | PROLIM PLM
Based on @JeanMA post, my suggested course is to
- define UGII_TEMPLATE_DIR
- move ONLY the PAX files you want into that folder (from the indicated places in the docs)
If you are doing this for multiple users, and don't have a configuration already set up on a network drive, I suggest you download the appropriate version of NXCustom from here:
https://community.plm.automation.siemens.com/t5/NX-Programming-Customization-Forum/NXcustom-Utilitie...
And follow the "Read me" files' instructions.
