How to know if postprocessing the last operation.
Hello guys, I need to output a /STOP at the end of every operation except the last one, because the end of program (M2) does not need a /STOP.
So, I need to know if the end of path event is the last one in order to avoid output /STOP.
Do you know how can I detect if I am postprocessing the last operation?
Frank.
Re: How to know if postprocessing the last operation.
Perfect.
Thank You.
Frank.
