How to rough this 4th axis part?
Material is 316 stainless and the maximum tool you can get through to rough and still have stock is 5/32
I tried slow feed slotting but tool did not last.
I thought about using an 1/8 and trichodial paths but I can only get that going one direction because NX can not 4th axis wrap out of the box.
I've reached out to Chigsev for his plugin but until then kinda scratching my head on this one...
2016-05-27_16562016-05-27_1657
Dennis Rathi
Creations Unlimited
15 REPLIES 15
Re: How to rough this 4th axis part?
That looks great! Solution partner legend!
More better:
From my experience - I can advise make few cutting levels. For few first level you can use more bigger tool.
Great! Question for topic starter - can you show "final result" in metal? Any images or movies from CNC?
Yes. I will post final picture of machined part today. Should be done in a couple hours. I "babied" speeds and feeds since only 2 pieces for samples (stepover is very fine as well).
Dennis Rathi
Creations Unlimited
What I ended up with...
Rough high level with bigger tools
2016-06-01_1352
Rough cylinder with smaller tools
Dennis Rathi
Creations Unlimited
Final part. Thanks for help from everyone on this forum who help me on this project.
2016-06-01_1355
Dennis Rathi
Creations Unlimited
Looks great, 316 always gives a nice result!
Sure would be helpful if Siemens added this into NXSmiley Sad
Damian Forsythe
Impact Manufacturing Group
NX 10.0.3.5
