How to set Manufacturing default options
I am brand new to NX11 and am wondering how I can set my Non-cutting moves / Cutting parameters etc. to a default so that I do not need to adjust them every time I create a CNC program?
For example, engage and retract is always pre-set to 'Arc - Auto' however I prefer using 'Linear - Relative to cut' and need to change this for every operation in every program. I assume there is a way to set these options to a default preference, I just don't know how to.
Again, I am brand new so I apologise if there is a super simple solution to this.
Neil
Re: How to set Manufacturing default options
https://community.plm.automation.siemens.com/t5/Tech-Tips-Knowledge-Base-NX-Manufacturing/Getting-st...
You can start with this video.Basically copy standart template parts,rename and change their contents than use them creating your operations.
NX 12.0.2.9 MP5 / Testing NX 1847
CanikSoft NC Post-Processing & G-Code Simulation
www.plast-met.com.tr
www.caniksoft.com
That's great, thank you!
I'll give it a go.
