How to set range of numbers in Common AnyController Commands
Hi  everybody
I want to set    3 < nToolID < 35    in ToolChange.prg with AnyController Commands .
I set to like this is wrong.
##LANGUAGE  AC
INT nToolID;
IF ( nToolID < 35 AND nToolID > 3 );                 this  CSE do not read.
How to set?
Appreciate everyone's help.
4 REPLIES 4
Re: How to set range of numbers in Common AnyController Commands
Hello yous707,
what is teh message you go when you say:
    "this CSE do not read."
What I can say already is that nToolID is defined, but has no value!
Thomas Schulz
Siemens PLM
Hello Tom
thank you for your reply.
CSE do not have message.
I mean   define  nTool=4 ,  CSE read   IF ( nToolID < 35 AND nToolID > 3 );    CSE skip this line.
how the defined the range of number?   for  example :   3 < nToolID < 35
please try this:
IF ( (nToolID < 35) AND (nToolID > 3) );
Thomas Schulz
Siemens PLM
Hello @yous707,
I had the same issue some time ago.
As mentioned by @SpaceTom, I had to add parentheses for each condition and it worked.
I hope this helps.
Thanks.
Jean Marcel
Application Engineer
Ally PLM Solutions | PROLIM PLM
