How to set up a dual lathe tool holder
I am having some issues reagarding setting up a dual lathe tool holder (holder shown below Station 03). It looks like it does orient the first holder correctly, but not the second one.
Is there a relation ship between the devise mount and the toolmount.Tool_holder.JPG
Any help or suggestion is appriciated.
Re: How to set up a dual lathe tool holder
I believe the way to do this is have the holder a device of its own, with 2 tool mount junctions (each oriented correctly).  Then add the 2 stick tools as 2 separate tool objects.
I do have the holder as a separate device with 2 tool mount junctions oriented correctly. It appears once I bring in the second tool it mounts it in the second tool mount junction. Orientation is off.
The tool stick I do sees is a "parameter Tool" this is always created realted to the turning/spindle workplane. You could try to define a different "working Angle" for each pocket.
Thomas Schulz
Siemens PLM
