How to setup shop document output to excel file only ?
How to setup shop document output to excel file only?
now when i create shop document will show 2 format excel and html files
i want excel only how to do ?
Re: How to setup shop document output to excel file only ?
Have you set the path to your excel installation in shopdoc_excel.tcl?
Mark Rief
Retired Siemens
Esteemed Contributor
Are you just trying to reduce the list of options listed when you click on the "Shop Documentation" icon?
If so, just edit the %UGII_BASE_DIR%\MACH\resource\shop_doc\shop_doc.dat file & comment out the ones you don't want.
Note the top of the path may be different if you have put your NX customized files onto a shared drive.
