How to skip an operation while postprocessing
Hi there!
I have a question concerning postbuilder and I want to skip an output of "MILL_CONTROL" or any other operation if it is the first operation in a list. Is there any command which allows implementing it? with respect, Alex.
Re: How to skip an operation while postprocessing
Do you want to skip ALL output, or just the tool change / initial  move / gohome stuff?
global mom_operation_type
global alex_t_machine_ctrl_flag
#MOM_output_to_listing_device "$mom_operation_name - Type = $mom_operation_type"
# See if "machine control" op
set alex_t_machine_ctrl_flag 0
if {[EQ_is_ge [string first "Machine Control" $mom_operation_type] 0]} {
	set alex_t_machine_ctrl_flag 1
Put in "start of path" event, as the very first thing the vaiable "alex_t_machine_ctrl_flag" to test if it is or is not a "machine control" operation
From there forward, you can use
Thanks for your help! Sorry, I am newbie here but could you explain what I should write in order to skip all the operation
Anybody knows how to skip the whole operation?please help
I see three ways for this.
For each of them you need some basic understanding of MOM events in general
1.
use MOM_abort_event in every event, together with recognition if it is operation which you want to skip or not.
The recognition might look similar to what Ken suggested
- in this case all procedures in the event after MOM_abort_event are skipped! - you should keep it in mind
2.
use PB_CMD_before_output. You can set mom_o_buffer to empty string in operations which you want to skip
- in this case all procedures in the operation are NOT skipped! only output is suppressed - you should keep it in mind
3.
use MOM_post_oper_path to postprocess only operations which you want.
Marek Pawlus, NCmatic
Development: C#, Tcl/Tk, CSE
Many many thanks!!! Both of you for your help and for a powerful incentive to study
Postbuilder!
If I remember correctly, there is also MOM_skip_to_event, but I don't know in which NX release this was introduced.
