Re: How to switch back to the older "Simulation control panel" ?
Hello Ducaero,
About the M1 use case it is working as expected when using any OOTB example in NX12.0.2
One idea could be to check the M1 customization in your CCF/ MCF. If that is implemented differently as in the CCF it might behave differently.
With your second request I assume you refer to simulate multiple operation.
It is planned to bring it back into the system, a release is not yet defined.
Thomas Schulz
Siemens PLM
