How to transform a generated tool path around the Axis or a line
Hi i have a generated a tool path on one face of  a twisted shape. Now i want to transform it around its middle axis on all of the the remaining faces. I am trying OBJECT------>transform tool but i am unable to get required results. Can any one help me in doing this.
Re: How to transform a generated tool path around the Axis or a line
Hi all
i have managed to resolve this issue by myself. Thanks every body
Would you mind sharing your solution? I was able to transform this using Rotate About a Point with a specified angle of 72 degrees and Number of Non-associative Copies set to 4. I'm just curious if you used a similar method or something different.
@jkane1
i didn't do any thing special ,just done as shown in screen shot.
But now i am curious ,how did YOU use specified angle of 72 degree and number of accociative copies 4.
Here are my settings. You can use Instance or Copy. The point I specified is the point you put at the MCS origin. The vector I specified is the Z axis of the CSYS at the bottom of the part.
thank you for sharing your method.
i didn't realy know about this
