How to use check stock in soldprofile 3D
Hello
3 REPLIES 3
Re: How to use check stock in soldprofile 3D
I used other operations
In the Obstacles operation, define the Cutting Edge and add the crop.
Better would be ZLEVEL_PROFILE or PLANAR_PROFILE
Best regards PaLi
If it just planner chamfering... I'd just be planner milling
You can easily shorten your line picks to avoid the wall
-See attached
Using a sketch curve is a better option. because you can control the interference with a sketch dimension.
I did it by projecting the edge, Then made a line for control distance and trimmed the "linked" projected curve with "Trim Recipe Curve".
** Now I have a dimension, (which could relate to an expression if I was controlling many).
I edit the sketch dimension and regenerate... I can get really close.
It's a linked edge so if you move a face the drive curve moves too.
I also used cutter comp, cause I know my guys would want it for fine tuning
Unfortunately does not look like the check is working the way you want in the process you chose.
{Paul Schneider}, {CNC Programmer}, {DRT-Rochester}
Production: {NX11.0.2,MP5, NX12.0.2, MP4}
