How to use excel to save the machining data in the correct txt format?
The excel output the library like below without Vertical bar between each column
What it should be:
Re: How to use excel to save the machining data in the correct txt format?
I found the solution:
1. copy whole data of sample_machining_data.csv, then paste to a new excel file, this new excel file format has to be in *xlsx format.
2. follow steps in this video: https://www.youtube.com/watch?v=RM6L8sRIPpU
