Hub finish alternative operation
Hi!
I am looking for an alternative operation to hub_finish from multi_blade group. Basically I want to finish the hub not touching the blades. I have nx learning edition, thats why i cannot use hub_finish. Any suggestions ?
Best regards,
Marco
Re: Hub finish alternative operation
Few years ago I build ugopen application for hub milling. Later I can show few images.
that would be awesome if you could share some help Smiley Happy
looks like i found the solution by dividing face of hub between blades and then milling this with variable contour and interpolated vector Smiley Happy
