I have another question about contour_area.
First, sorry, I do not speak English well..
Using contour_area to cut red section.
I will use Flat_10 tool.
purple section is dp:-10
This point, I have a question.
I want not contact purple section. and just cutting Z-9.95
The way I use "offset face or pull face".
It means edit model.
Is there any other way?
And I don't understand about "Specify Check"
Please explain "Specify Check"
Thank you.
4 REPLIES 4
Re: I have another question about contour_area.
Set a check area on the flat and put .005 check stock?
Dennis Rathi
Creations Unlimited
Pick the purple face as check geometry.
Be sure to set the Type Filter to Face, not Solid Body.
Add Check Stock to the custom data.
Mark Rief
Retired Siemens
Thank you for yout advice Smiley Happy
Thank you. so much Smiley Happy
