I need a help on tool path editor!!!!
I from NX8.5 upgrade to NX10.0 in tool path editor I met a trouble. When I use scope of choosing a path, I found the choice of path will not highlighted, I want to know where the problem is,
I need help.!!
aq.PNGNX10.0.3
xx.PNGNX8.5.3
16 REPLIES 16
Re: I need a help on tool path editor!!!!
Try a refresh (F5) Also you could update your video drivers. Look in spreadsheet below for the 4th tab. (certification matrix) find the recommended driver for your system. http://www.plm.automation.siemens.com/en_us/support/gtac/certifications.shtml#lightview%26url=/en_us... (Graphics Card) Certifications%26description=%26docType=xls
Glenn Balon
Production: NX 12.0.2 MP7 Primarily CAM
Thank you for your help. Regretfully, refresh and can't solve this problem, I in the same device using two versions of the NX, had two different results, the driver may not have problems, but I will try to update it.
I have 10 and 11. I will test on my system tomorrow. I use this function also, and seeing what is selected is very important.
Glenn Balon
Technics NC LLC
847-494-5366
Glenn Balon
After the driver update, the problem still exists
Looking forward to your test results
editor_highlight.pngNX 11.0.1.11 MP1
Works in NX11, will test in 10 later
Glenn Balon
editor_highlight_nx10.pngNX 10.0.3.5 MP13
NX 10.0.3.5 MP13 seems to work ok also.
Try updating to latest Maintinance Pack. Otherwise open an IR.
Glenn Balon
Problem is in the range of choices, you can test again
问题在于选择的范围,您可以再次测试
