I want to creat a template for CAM
Dear,
I download file demo of Siemens, It have a lot of teamplate standard for CAM the same picture
How to do this actions? Help me?
13 REPLIES 13
Re: I want to creat a template for CAM
It should be in the PAX file in your templates folder from what I remember.
Using NX 8.0.3.4
You need to create setup assembly templates, add them to the setup library, and then create your own pax file that is merged with the system one to display the file new dialog that you show.
The attached presentation is a little old, but you will get the idea.
A note to customers - the image is from our internal and partner demo environment, which is not distributed to customers as part of NX CAM.
Mark Rief
Retired Siemens
How i can create a PAX file it can show what i want, please help me detail more !
See the slides numbered 30 and 31.
Copy the manufacturing pax file from the install to your location, remove all the OOTB entries, and replace them with yours as shown on #31.
Mark Rief
Retired Siemens
i don't see any Slides numbered 30 and 31 .
In the lower left corner of the last 2 pages of the pdf file, do you see "Page 30" and "Page 31"?
Mark Rief
Retired Siemens
Please check the pdf file ,i don't see what you say, See in the picture of my pdf file
Does your pdf file have 10 pages?
Mark Rief
Retired Siemens
Yes, my pdf have 10 pages , please capture a picture to me !
