(IMPORTANT) Error when Post-Processing
Hello everyone,
I am getting this error when trying to post process:
Could not find file to load.
File Name: {Installation Dir} mach\auxiliary\PPdecrypt.dll
Fucntion name: ufusr
This comes up when retrieving a new machine (custom one) from the library as well.
I checked for this dll in the specified folder but couldn't find it.
Any help would be appreciated.
Paras Raina, Technical Head, MSC Systems Pvt. Ltd. (India)
NX 12.0.2
Solid Edge 2019
Re: (IMPORTANT) Error when Post-Processing
You need this dll.. Your postprocessor is encrypted and dll is decryptpr
Can you upload files?
@Chigishev
Thanks for the suggestion.
This file was for decryption. I found it in other system where the machine was already installed from PP kit. The file is supplied with the PP kit as well.
NX 12.0.2
Solid Edge 2019
