IPW error
When i run the manufacture command for a project, it contain following movements roughing,semifinishing,finishing while doing semifinishing, i have used 3D in inprocess workpiece(IPW) in cutting parameters then click on generate program a error message "An operation must inherit blank geometry from geometry group when using 3D IPW" appears what can i do please send me any solution
Re: IPW error
To be able to use the IPW so do you need to specify your stock inside the WORKPIECE geometry group.
Your operation then needs to inherit the stock from the WORKPIECE group.
Choose the WORKPIECE under the geometry tab inside the operation, choose the WORKPIECE that hold your stock.
Please see the attached image.
Hope you get it to work!
