IS&V tilting head with offset pivot point help
I am building a machine tool support kit using OOTB sample sim15_millturn_9ax. I am using the fanuc cse driver files. The machine has a B axis tilting head but the rotation pivot point is offset from spindle centerline. I have found that the method GMe_SetToolLengthCorrection has a hard coded value from spindle face to rotation pivot point (220mm). I have tried to edit the formulas within the method to account for the offset pivot point without any luck. Any help would be greatly appreciated.
