[ISV] Program name 'TOL' not found.
Solution Partner Innovator Solution Partner Innovator
Hi
An error occurs during ISV setup.
"Program name 'TOL' not found."
I do not know where to set the current error block in the machine configurator.
Thank you.
Re: [ISV] Program name 'TOL' not found.
easily create a TOL.spf subprogram file in subprogs folder of the machine and enter a RET or M17 inside, if the subprogram should do nothing.
Thomas
Hi
I have additional questions.
Origin can not be applied. How do I set it up?
