[ISV] Tool change - Turning
Solution Partner Innovator Solution Partner Innovator
Hi
NC Code block is..
"N1 G40 T1100"
"N2 G00 Z143. T1111".
Tool number is "11".
T1100 is the tool change motion and T1111 is the adjust setting.
How do I setup a simulation?
Reference sim11_turn_2ax_fanuc. thank you.
Re: [ISV] Tool change - Turning
You need to customize the T meta code. First check if 3rd and 4th value is zero, if so do as usual.
If not don't call the tool change, but activate tool correction (currently done with H)
Thomas Schulz
Siemens PLM
