[ISV] Turing - 2X Diameter Programming
Solution Partner Innovator Solution Partner Innovator
Hi
I refer to "sim11_turn_2ax_fanuc".
The current X axis of the machine is output as Diameter value.
The problem is that the X and I values work twice as much in the simulation.
Where do I change my settings?
Re: [ISV] Turing - 2X Diameter Programming
Hello
activating / deactivating of the diameter mode in Fanuc is done by a G code.
G10.9 X0 --> radius programming
G10.9 X1 --> diameter programming
If that is not part of your NC code you can add that inti an ini file
Thomas Schulz
Siemens PLM
