ISV message "unspecified error when executing method 'getJointNumber'
Solution Partner Innovator Solution Partner Innovator
Hi
I'm using NX10.0.3. machine name is DMU50 evo.
Machine type is 5axis table-table(BC)  and Controller is Heidenhain.
And when I try to simulate my NC code I get the next
error massages:
I think there is a cause in HeidenhainTNC.ccf file.
Reference machine is sim14_mill_5ax.
Where could be the problem?
Re: ISV message "unspecified error when executing method 'getJointNumber'
Please check the global variables in the MCF file.
GV_strFourthAxisName etc. there is a list inside the OOTB PDF:
Working_with_OOTB_MACH_Simulation_Examples.pdf
Appendix G
Thomas Schulz
Siemens PLM
Look into the CSEInitializeChannel method. There is a getJointNumber(..) on hardcoded axis strings. This has been fixed in NX11 or the latest NX10 (I´m not really sure which version) To avoid this message you have to modify your CSEInitializeChannel method.
Thomas
