Is it possible to INCLUDE multiple ude.cdl files?
PLM World Member Creator PLM World Member Creator
Inside the ude.cdl file I want to source my own cdl file as well as the Siemens_Cycles.cdl.
Like this
INCLUDE {$UGII_CAM_USER_DEF_EVENT_DIR/Siemens_Cycles.cdl}
INCLUDE {$UGII_CAM_USER_DEF_EVENT_DIR/MY_ude.cdl}
But they are not available like they should be. If I reorder them (putting my_ude.cdl first), I get the information from my_ude.cdl only. Attached is an image with the Siemens cycles first...
Thank you
-Danny
Yes - you need to put the file names inside the {} with a...
Yes - you need to put the file names inside the {} with a space in between.
Take a look inside Siemens_Cycles_plus_ude.cdl to see an example of combining multile user defined event files:
INCLUDE {$UGII_CAM_USER_DEF_EVENT_DIR/Siemens_Cycles.cdl $UGII_CAM_USER_DEF_EVENT_DIR/ude.cdl}
Igore the wrapping if you see it - this is one long line of text.
Mark Rief
Retired Siemens
Re: Yes - you need to put the file names inside the {} with a...
Thank you for the speedy response. I am grateful.
