Is there a way to save existing settings when implementing a major upgrade?
Hi everyone, I wonder if someone is able to help us.
At my company, we are about to do a major upgrade in the NX software (NX8 to NX9). Is there any way of saving all our custom settings so that we can use them again once we have installed the new software?
Which settings are you trying to migrate?   Customer Defa...
Customer Defaults can be migrated - There is a procedure in the help found at System administration --> Customizing the NX installation --> Customer defaults --> Migrating customer defaults.
Settings in template parts should be reviewed to see if they still apply, and then set manually in the new template parts.
Mark Rief
Retired Siemens
