Journal to test CAM performance
Attached find a VB journal to test the performance of tool path generation and tool path gouge check.
It also saves the results to a log file with the most important specifications of the NX release and system the test was done with.
Have fun Smiley LOL
Re: Journal to test CAM performance
What about ISV?
Smiley Happy
Dennis Rathi
Creations Unlimited
Recording a journal of IS&V resulted in the following:
' NX 10.0.3.5
' Journal created by Stefan.Pendl on Thu Jan 19 10:27:03 2017 Mitteleuropäische Zeit
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
Dim workPart As NXOpen.Part = theSession.Parts.Work
Dim displayPart As NXOpen.Part = theSession.Parts.Display
Dim cAMSetup3 As NXOpen.CAM.CAMSetup
cAMSetup3 = workPart.CAMSetup
Dim kinematicConfigurator1 As NXOpen.SIM.KinematicConfigurator
kinematicConfigurator1 = workPart.KinematicConfigurator
Dim objects1(0) As NXOpen.CAM.CAMObject
Dim nCGroup1 As NXOpen.CAM.NCGroup = CType(cAMSetup3.CAMGroupCollection.FindObject("OBEN_300000100"), NXOpen.CAM.NCGroup)
objects1(0) = nCGroup1
Dim isvControlPanelBuilder1 As NXOpen.SIM.IsvControlPanelBuilder
isvControlPanelBuilder1 = kinematicConfigurator1.CreateIsvControlPanelBuilder(NXOpen.SIM.IsvControlPanelBuilder.VisualizationType.MachineCodeSimulateCse, objects1)
isvControlPanelBuilder1.SetSingleStepMode(NXOpen.SIM.IsvControlPanelBuilder.SingleStepModeType.StepOver)
isvControlPanelBuilder1.SetSpeed(5)
isvControlPanelBuilder1.PlayForward()
isvControlPanelBuilder1.Destroy()
End Sub
End Module
I think this should enable you to create a similar performance test for IS&V out of mine for tool path generate Smiley Wink
