KUKA IR663 Robot, external axis, Mach 3 CNC and NX postprocessor
Here new episode for my story about old-old-old (1993) KUKA Robot, MACH 3 CNC. Customer add additional external axis and we made wood test. Not so bad...
4 REPLIES 4
Re: KUKA IR663 Robot, external axis, Mach 3 CNC and NX postprocessor
Great! Not so fast, is it Mach3 problem, or step motors, or you set small feed value?
Too many points in toolpath....
did you just postprocess XYZ and tool axis vector IJK for tool tip
or did you calculate each joint/motor angle?
Each joint value:
X for first rotary axis
Y and Z for 2nd and 3rd linear axis
A and B for next two rotary axis
And C external axis..
