Laser deposition operation
Hi everyone!
There is someone who is able to explain me how I can create laser deposition operation in NX, because I can not find it. I need special additive manufacturing mode to do it ? I hope someone is able to help me.
best regards
Re: Laser deposition operation
NX is offering support for Multi-axis Deposition (DMG-Mori use case) and Fixed Plane Deposition (powder bed use case). The software for this second use case is brand new and now available in a first version with NX11.0.1. Both solutions require dedicated (new) licenses.
You will need to provide more detail before we can help you with your question.
Which of these two use cases are you asking about?
If you refer to the powder bed use case, are you talking out printing metal or plastics?
What 3D printer would you like to use?
Etc.
Tom van 't Erve
NX CAM Development
