Lathe IPW from non round part
Honored Contributor
Honored Contributor
Our machine shop just asked me about this...
User is programming a part, made from hex stock, to be turned on a lathe.  He's using a spun outline, so the IPW that is output is round, and not hex, which doesn't work for the next mill operations.
Any tips on how others do this?
-Dave
NX1867(if it had versions) | Teamcenter 11.6 | Windows 10
Re: Lathe IPW from non round part
You need to model in process workpieces...
This is a Tip video i did some tome ago, it will explain the process.
https://community.plm.automation.siemens.com/t5/video/gallerypage/user-id/12/video-id/MzaG1iYjqGmomH...
