cancel
Lathe Tool Z Mount Positional Error
     When Retrieving the Lathe machine retrieval with Siemens NX 10 Manufacturing mode, when I load the Library's Lathe (sim11_turn_2ax_fanuc_mm) 2-Ax Turn Horizontal Mill (the 1st default lathe in the software) the tools in my carrier and pocket remount on my turret with a Z positioning below the actual slot.
     How can I position my lathe tools Z mounting to be correct?
     The issue is displayed in the below picture:
Re: Lathe Tool Z Mount Positional Error
I was able to manually design holdsters into the machines turret in model mode and just position the tool with X and Y mounting underneath the slots. Simulate machine runs perfect then although there are some write (save) issues editing the imported machines turret.
