Lathe Tool cutting past part when not wanted to
I have noticed this problem for a while and haven't figured it out yet. My lathe tool is cutting past the stock, in thise case around .015" which I think is common in all cases. The extend distance is set to 0 for the retract. not sure what parameter would do this.
Using NX 8.0.3.4
Re: Lathe Tool cutting past part when not wanted to
It's picking up on the radius of your insert, not an operation parameter.  I made an operation with a normal .031R insert.  Then copied both tool and tool path, changed only the radius on the insert, and now it doesn't cut past the end of the part.
Jake Hardwick
CNC Programmer
Senior Aerospace AMT
Production NX8.5.3.3 Beta testing NX10.0.1.4
Jake Hardwick
CNC Programmer
I see, I guess there is no way to say stop at contact point? If not I might submit an enhancement request.
Using NX 8.0.3.4
Have you tried in a later release?
NX 8 is no longer under development, so things might already be there in NX 9 or 10.
