Library conversion from NX10 to NX11
What's the best way to convert the NX10 library to NX11.
We use device, feeds_speed, machine and tool library.
Sven
NX11.0.1
Re: Library conversion from NX10 to NX11
Inside of NX11 in the manufacturing application select "Menu => Tools => Convert tool library" there you select the one of NX10, which will then be converted into the one for NX11.
There is also a section inside of the NX help, which is required to be read for better understanding.
