Linked body is unknown by using NX12
Hello everyone
We use NX 10.0.3.5 Mp 18 in production. Now im testing NX12.0.1.7 and i have an issue... If i open an existing manufacturing part, the linked body is unknow.
If i choose the part as "Make as displayed part" and return to the Manufacturing setup, the body is up to date.
Is there a setting in the Customer Defaults?
There was a warning with the Material. If i selected in the Customer Defaults the "Update Material Properties from Library on Part Load"
I don't know if there is a context with the Material.
Thank you very much for your assistance Smiley Happy
Production: {NX 10.0.3.5 MP18}
Testing: {NX 12.0.2.9 MP03}
6 REPLIES 6
Re: Linked body is unknown by using NX12
This is normal behaviour, since the default settings is to not load components fully. When you make a component the displayed part, it gets loaded fully.
This has also been the case in NX 10, they might not have displayed the state of the link correctly.
Have you changed the assembly load options in NX 10?
Thank you for your answer.
I don't know exactly wich load option was changed in NX10. Those settigs was not made from me Smiley Frustrated
Should i compare the "OOTB NX12 " Settings with the Settings in our NX 10?
Have you any suggestion in wich tab this could be changed?
Thank you very much
Greetings from Switzerland :-)
You just check the assembly load options dialog of both NX versions.
See "Home Tab or File => Assembly Load Options" and ignore the obvious changes from the what's new guide of NX 12.
HomeAssemblyLoadOptions.PNGHome => Assembly Load Options
FileAssemblyLoadOptions.PNGFile => Assembly Load Options
Hope this helps.
Thank you Mr. Pendl for your Help
Those load options seems to be similar Smiley Frustrated
Are there some other loadoptions availible?
Have a nice weekend Smiley Happy
There are no other load options available.
I still think that Siemens has corrected the display, since the state of the link was always unknown if the source part was not fully loaded.
Have you tried the new options from the drop-down list, if there is one that gives you the expected result?
Thank you for this Tipp Smiley Happy
If i find the setting or my fault (maybe a template) i post my results here.
