Links Other Posts
About Mill-Turn, Link Other Posts must set Head in UDE first, but if there is more than one machine and want to switch to select Post, we need to change the name of Head. Is there any more convenient way?
6 REPLIES 6
Re: Links Other Posts
I doubt there is an easy solution for that use case, but you may can give it a try to use the more modern posts and no longer work with linked posts. Check out the installed examples.
Thomas Schulz
Siemens PLM
put UDE head on some methods  so you need to only put operations into the methods to decide what post you want to use.
You can also edit template to have these method already prepared.
Hi,Juraj
First of all thank you for your reply.Smiley Happy
I am using this method right now.Because of different machine post, to be set different Head, when I finished the operation was originally produced in the A machine, temporarily want to change B machine, this time becomes troublesome.
Hi,Thomas
 I also think there is a faster way In the NX.
Can you guide your current practice?
linking posts is one way.
ANother way is to switch kinematics in the same post. By UDE or whatever.
I do not know all the details, but with NX we do install example machine tools.
You will find them:
Library: ..mach\resource\library\machine\installed_machines
CAM examples: ..\mach\samples\nc_simulation_samples
Some complex one included e.g. sim10 sim15 sim17 they will not work with linked posts.
May it help if you check them out.
Thomas Schulz
Siemens PLM
