METHODS Final Floor Stock
Hi, I was wondering if there way a fay to add a Final Floor Stock to a machining method? I'm working with a floor_wall_ipw operation.
Re: METHODS Final Floor Stock
Only Part Stock can be inherited. You can see this in the operation Cutting > Stock dialog -- only Part Stock has the inheritance lock icon next to the value.
Mark Rief
Retired Siemens
I see, I was hoping there would be some way I could customize it or something but I have another solution for what I want to do.
Thanks again!
