MKE: support for block IF
We have found that MKE is supporting block IF statements starting with NX 10.0.3 MP16 by accident, after we have checked the reliability of pilot holes for gun drilling in NX 11.0.2 MP2.
In the rule "MillDrill => DRILLING => TwistDrill => Drill_in_center_S1P" in NX 11.0.2 MP2, we found the following condition:
REM New since 11.02
IF (is_defined(mwf.MACHINING_RULE) AND mwf.MACHINING_RULE = "Guidance_Hole" ) THEN (
oper.Predefined_Depth_Status ="true" AND
oper.Predefined_Depth_Type ="ToolDiameterPercentage" AND
oper.Predefined_Depth_Value = 150.0
Due to this we asked a technical question at GTAC if block IF statements are supported and what the initial release of this support is.
Until now, we only thought that the following syntax was supported:
IF {condition} THEN {expression}
REM or
IF {condition} THEN
    {expression}
REM or
IF {condition} THEN {expression} ELSE {expression}
REM or
IF {condition} THEN
    {expression}
ELSE
    {expression}
Which was resulting in multiple duplicate IF statements, if one had multiple expressions for the same condition.
Starting with NX 10.0.3 MP16 one can now create block IF statements in MKE:
IF {condition} THEN (
    {expression} AND
    {expression}
) ELSE (
    {expression} AND
    {expression}
An example for this syntax is below:
IF mwf.TILTED_TOP_DEPTH > 0.0 THEN (
    oper.Stock_Part = -0.1 AND
    oper.Top_Offset_Value = 3.0
) ELSE (
    oper.Stock_Part = 0.0 AND
    oper.Top_Offset_Value = 1.0
Happy coding Smiley Wink
Re: MKE: support for block IF
In regard to this, would it be possible to use nested IF conditions now?
Something along the lines of:
        {expression} AND
        {expression}
    ) ELSE (
        {expression} AND
        {expression}
) ELSE (
    {expression} AND
    {expression}
Thanks in advance for any pointers about this ability.
Hi Stephan,
In NX 9, I had faced a few troubles with it, and I used Functions instead. Great to know the IF statement is now working better than before!
Thanks for sharing it!
Salvador Peregrina
Manufacturing Team Leader| NX 11.0.2.7
To answer my own question, I have had a need for nested IF conditions, but MKE barked at me with a syntax error.
So nested IF conditions are not supported by MKE currently Smiley Sad
